This command displays the status of BGP or OSPF auto-peering and the learned auto-peering interfaces and corresponding remote peer information.
| ospf | Shows OSPF auto-peering status and interface information. |
| bgp | Shows BGP auto-peering status and interface information. |
N/A
All existing BGP show commands can be used to display the status of BGP peers and routes.
The following example shows the status of BGP auto-peering:
# show auto-peering bgp Type : BGP Password : Id : 0 Router ID: 2.2.2.102 AS : 102 Peer Id Password ----------- ---------------------------------- 2222 None 2223 #$75Zvb3YfCBE/4+eSQE5dA5T2lmhF5A== VLAN Neighbor IP Address Router ID Remote AS Port Fabric ID Peer ------------- ------------------------ --------------- ---------- ------- ---------- ----- SYS_BGP_0002 fe80::204:96ff:fe9d:66e8 3.3.3.103 103 69 0 Yes
# show auto-peering ospf Type : OSPF Id : 0 Router ID: 1.1.1.54 VLAN Router ID Port Fabric ID Peer ------------- --------------- ------- ---------- ----- SYS_OSPF_0002 1.1.1.55 19 0 No
This command was first available in ExtremeXOS 22.5.
Peer ID and password information was added in ExtremeXOS 30.5.
The ospf option was added in ExtremeXOS 30.6.
This feature requires the Advanced Edge license. For more information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
